I asked him about unplugging the tps and he said I've unplugged it and the idle goes way up. Then hit's fuel cut goes back down, and repeats this process.
so mods, aluminum driveshaft, Spec stage 2 clutch and flywheel (good up to 590 hp) brand new brake system, new calipers/lines/pads/rotors, stainless mesh intake filter(, new 2jzgte TPS/thermostat combo, Optima Red Top 800ccamps, hks downpipe, Custom 3" exhaust from downpipe back with high flow cat, brand new Yoko rubber on the rears, boost/oil pressure gauges,torsen differential,
Those are all the mods...Is 3500 a good price with the tps problem?
