Old 07-08-2010, 02:24 AM   #10
Originally Posted by boosted View Post
I asked him about unplugging the tps and he said I've unplugged it and the idle goes way up. Then hit's fuel cut goes back down, and repeats this process.
so mods, aluminum driveshaft, Spec stage 2 clutch and flywheel (good up to 590 hp) brand new brake system, new calipers/lines/pads/rotors, stainless mesh intake filter(, new 2jzgte TPS/thermostat combo, Optima Red Top 800ccamps, hks downpipe, Custom 3" exhaust from downpipe back with high flow cat, brand new Yoko rubber on the rears, boost/oil pressure gauges,torsen differential,
Those are all the mods...Is 3500 a good price with the tps problem?
Ft Collins?? Is the seller a member on here by chance?
Optima = not an upgrade.
stainless mesh filter = might as well just put a sock over the turbo's inlet if this is any of the brands I've seen tested.
Torsen Diff = Search SupraMania for "grenaded diff"... these are really cool diffs, but the MKIII's torsen does not live long if you're putting down a lot of power or a lot of aggressive launching.
Other than all that, hell, if it's not worth fixing it's worth parting out.... you'd probably break even.
You and the seller apparently don't know what fuel cut is nor what the real fuel cut is. It's not hitting either kind while just sitting there.
