LCA... Lower control arm? I must be confused, what precisely are you talking about greasing with said fitting? Squeaks are a given with high density bushings... lube them up with a good dry lubricant and you should be fine for quite a while. I've also heard that silicone spray lubricants work well but require reapplication more often (but they're easier to apply).
