Thanks cre for the timely reply. I read that some ppl drill the lower control arm where the bushings are located and install grease fittings, but if you're saying to avoid that I will heed your advice
 Supe supe!
1986.5 Supra Manual Red Mica(Maroon) w/wing: Custom sound system, 18" Tork Revos, smoked tail lights, markers, and turn signals.
Mods: Eibach lowering springs, Energy poly front upper and lower control arm bushings, custom cold air intake, solid engine mounts, Magnaflow, short shifter, Optima Red Top, other custom fabrications..and yes a bra.
