The R154 transmission (the stock 7MGTE 5 spd transmission) can be used on M blocks and JZ blocks. If the transmission you have did come from a 7MGTE, then you will need a JZ transmission bellhousing to mount them together.
You will also likely need a different driveshaft, but I don't know for sure if the same differences in 7M supras apply to 1JZ supras.
