What did you find wrong? I have this same problem and just can't figure it out. I didn't have this problem until after I removed the engine for the flywheel and clutch and did a head gasket job while I was at it. Put everything back together and now I have the exact same noice in the exact same place. I already checked and adjusted my valve clearances and helicoiled my exhaust manifold, replaced injectors with Rc engineering while I was at it. I could really use some insight.
1991 Supra - Turbo - 5spd
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
550cc injectors (2 sets, venom direct fit, RC engineering)
2.5" intercooler and piping
Aluminum radiator w/dual electric fans
ARP bolts w/MHG
Full-auto turbo timer
Fidanza Flywheel & Stage 2 Clutch
spark plugs and wires.
power steering pump
cold temp start switch
engine top end rebuilt
transmission opened up and inspected at a tranny shop when the flywheel and clutch installed last week.
