Thread: Troubleshooting
Old 07-17-2010, 08:26 PM   #13
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Durandal View Post
The buffering I was referring to was mentioned here called wave form shaping.
http://www.mkivsupra.net/vbb/attachm...6&d=1234196778
Great info - thanks for the post! +1
Based on this info, I'd now have to advise not to bypass the ODO; if re-flowing the solder joints doesn't fix the issue, then ideally the ODO should be replaced.
However, if the ODO is bypassed, it's possible that the waveforms from the tranny speed sensor are sufficient to trigger the ecu a very high % of the time (wthout wave form reshaping by the odo)....
Life begins at 30psi.
