Old 07-17-2010, 09:27 PM   #12
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Durandal View Post
Yah removed the tape today and there are crimp connectors and all the wires are red striped black wires which are grounds i believe? I don't know why it is the way it is though.
Crimp connections in general are good (Toyota never uses solder - it's a less relaible connection over time on a moving/vibrating vehicle than a proper crimp). That said, I'd guess you're referring to a cheap plastic press crimp.
Regarding the wire colors in the harness, it's best to refer to the TSRM:
http://www.mkiv.com/manual/1995_elec...ual/index.html
Life begins at 30psi.
