The 400 series Lexus (SC, LS, etc) use an AFM which allows approximately 25% more UNMETERED through. You MUST add approximately 25% more fuel as a result (~550cc injectors are just about right). This does allow you to boost more as the ECU thinks the engine is getting 25% less air than it really is.
DO NOT run a Lex AFM if you do not have upgraded injectors!
