I do see about half a quart or more between every couple fill ups. what do you mean overhaul? a good IC cleaning or an engine rebuild.. gasp*
I can see my oil dripping from the bottom of my engine. Left side beneath the manifold twords the front. bottom of the engine, right were the block meats the oil pan. could this be an internal leak from the cps
whats a recommended step along with check for leaking in the cam sensor.
