Old 07-29-2010, 03:50 AM   #14
btwilson86
Super Moderator
btwilson86's Avatar
Since you're planning on pulling the motor, oil pan is easy to remove.
Keep in mind Toyota uses a flow-able gasket material for the pan gasket, so it's sticky on there, lots of gasket material removal once it's off. I have used the fel-pro oil pan gasket in the past and never noticed any issues with it, but I'd recommend you use the original stuff for reassembly. Must be some reason for no gasket on it, right?
