I may not have made part of my point on the spark plug thing very clear. You may need to try a couple different temperatures of plug before you find the "right one", start with the stock 5's. If you're bumping the timing up to or past 15 degrees BTDC then step to a 6. Check the plugs frequently for signs of detonation and fouling and replace with another temp as merited.
