Old 09-13-2005, 09:22 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
at the top of your brake pedal you will see a little unit with a switch on it which the brake pedal leans against
when the pedal is off it pushes the switch so it knows to turn off the brakes... if it doesn't touch it thinks you are braking
adjust the nut behind the switch so that the switch is touching the pedal when you aren't pushing it
make sense?
Pics of my build.
Do a diagnostic first!
