Old 08-05-2010, 09:04 PM   #4
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by TZimmz View Post
definatly a 6 spd and definatly twin turbo
it stock with a blitz short ram
and a intercooler piping kit
My first suspect would be a vacuum leak ... anywhere within your charge-air system. Most likely you should start with the intercooler piping kit - for example, sometimes a t-bolt clamp can squeeze a pipe so hard as to dent it, which can in turn cause a vacuum leak. Do you have the tools necessary to pressurize your charge-air system?
Life begins at 30psi.
