so here we go.
i started my project with auto to manual swap on a 1986 7m-ge
i decided it would be less frustration to remove the engine harness from the engine, pull the engine, and pressure wash both engine and bay, and start fresh with the 5speed.
im now at the end a week later (only get to work on it @ night cuz of my job)
and somehow i forgot to label where i removed the 4 grounds from near the starter.....(im rather pissed @ myself...)
2 are from the engine harness, and the other are the positive and negative terminals from the battery.
so far this tells me nothing...
http://www.cygnusx1.net/Supra/Librar...Section=ST&P=3
also i have a haynes manual, and all it helps with is how to check your cables for rips tears and cuts... so thanks i can now use my eyes...
can any one help me...
maby someone will want to get under there car and look for me, just let me know for both terminals
and it would be good to know where the 2 grounds from the engine harness go....(both leading through the intake manifold and passed the injectors to somewhere near the starter...)
thanks a million in advance
