a heat shield and box is the same idea. anything to keep the HOT air from your air filter.
Id suggest placing your air filter down were the snorkel for the stock air box is by running a pipe from the maf to the air filter and than just blocking it off were the original box used to be. have a smart clean engine bay with cool air. make sure you put one on the side were the rad is.. block the rad hot air too..
thats what im doing once i get my air filter
