Originally Posted by Green7mgte
rad pressure tester.. go rent one from autozone or buy one.. its like 60 bucks.. they pressurize your system. *do not go above 13psi* and you can actually watch to see where its leaking from.
i second that.
i thought id just get him to check the obvious first.
if you get down to work, you can, from the cheapest thing to the most expensive, and find your problems quickly.
