Thank you for that info 93.5 JDM
Now I have a couple more stupid questions. where is/how do I take off the intake piping off the turbos, and what does "shaft play" mean and if there was oil in the intake, is that an easy fix or is the engine no good anymore?
When I test drove the car, The gears did seem to grind a bit, but I did not listen for the winding of the transmission when not stepping on the clutch. I will do so and get back to you about it.
