it looks like you can mod the timing instead of just the fuel curve on that maft pro system- i haven't seen a piggy back also tune the ignition timing before - it looks basically like a daughter board to hook up to the existing ecu that you tune with to mod the existing ecu code but through the maft pro computer. is this correct?
