Originally Posted by Supra Saiyan
Your not losing coolant are you? How often are you refilling your coolant? ever?? If your losing coolant.. BHG.. Anyways, i'm going to bed.. Good luck.. The others usually see new posts in the morning.
ok ty for the help. and no i rarely fill the coolant. i fully drained it and took it off when i did the drive shaft fix. could the trans pump stop working if you plug the hoses leading to the radiator? also when we went to put the timing belt back on the cams rolled back one notch. but i dont see that messing with acceloration.
