this is ware i see the smoke coming from. also this shield here rattles when i drive.
this has been this way since iv owned the car and was wondering if it is a bad thing? iv cleaned it up afew times but it just comes back so im guessing its a bad thing.
this is the inside of the throttle body. also she fires from cylinder 1. and if it prove its the trans i drove her in L to the store then back home in D she seems to be accelerated better. but then again my last test run she did the same thing then went back to acting up.
also if when i go back and reset the timing how do i keep the cams from turning? theres no hole to put a punch in to hold them in place well tightening the belt.
