Originally Posted by Green7mgte
what did your transmission diagnostic say?
oil in spark plug galley is fixable.
all that oil is an excessive amount of blow by. not that good. possibly one of your main front and main rear oil seals is most likely the culprit for the blow by.
this would be easyer if i could hook her up to a computer but when reading everything i get ether AT-30 or AT-46. unless the timing being off by one notch really messes up acceleration that much. about a month ago i did a transmission service on her new trans fluid and filter. before the test drive last night she was reading that the trans fluid lvl was ware it was suppose to be when i got home it said it was over now its saying its half full. i just checked it... it could be valve body or primary regulator thats faulty AT-109
