Old 08-19-2010, 12:03 AM   #14
afsvanderveen
afsvanderveen is on a distinguished road
u may have checked already but check the thermostat. If its stuck closed it will cause an overheating problem, then that leads to leaks and so on. Wrong temp thermostat can do the same thing if its really hot where you are.also i would suggest a system flush in case there are any blockages. As the coolant system like to build scale and will cause havock if left to long.One more thing, unfortunately in our cars if you have had a overheating problem and its been serious, chances are you have a bhd
afsvanderveen is offline   Reply With Quote
