Old 08-19-2010, 06:43 PM   #31
Green7mgte
Supra Forum Moderator
shitty idle.. poor acceleration. all the things that your experiencing now.
see above for explanation on what the cams do..
It does. Depending on how it shifted it can drastically increase engine heat OR it can drastically increase exhaust temps (if it's the exhaust cam); If it's the intake cam it can cause the intake valves to close too soon, choking the engine; or it can close it too late allowing a pulse to disrupt the incoming airflow, again choking the engine but in a very different way.
Originally Posted by btwilson86 View Post
being out of alignment can cause the vehicle to not spark in time. If the spark happens too early or too late, it will cause the vehicle to not fire.
wilson is talking about the cps.
but moral of the story is.. IF things arent TDC and your timing is off.. you will have shitty engine proformance.. + hazard
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
