Old 08-20-2010, 12:05 AM   #32
You can stop the cams from spinning by just putting a 10mm socket on one of the rear timing belt cover's bolts (one of the four behind the cam gears) and rotate until one of the spokes binds on the socket/extension. Have someone hold it in place if you can't work with a wrench in each hand (sissy.).
