Fuel pump controller? Your fuel pump only has one speed on or off. If u have high fuel pressure you need a new regulator. Or check for linked line under car where it might have came in contact with the asphalt. If ur pump is just really loud then it is on its way out. Walbro can be had for around 100 bucks.
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
