Originally Posted by Travis89Turbo
Fuel pump controller? Your fuel pump only has one speed on or off. If u have high fuel pressure you need a new regulator. Or check for linked line under car where it might have came in contact with the asphalt. If ur pump is just really loud then it is on its way out. Walbro can be had for around 100 bucks.
i appreciate ur reply...
Im trying to get my car to pass air care...it passed the driving test i just cant get it passed the idle test its not going well...my mechanic is telling me that i need to replace the "fuel pump controller" because it stays on high at all times......am i being mis informed? his plan is to find a new one or swap mine with his mk4 supra....i really need help guys my idle test is not going well at all its really high in hydrocarbons etc
