Definatly have symptoms of ball joint or possibly a strut. And ur friend watching under ur car while moving sounds dangerous I wouldnt recommend that at all. Easiest way to check ball joint is put it on a jack stand and grab the top and bottom of tire and see if u have any play. If u have any at all its a bad ball joint.
Keep your friends out from under your car
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
