Old 04-06-2010, 10:41 PM   #14
Busted Knuckles
Busted Knuckles's Avatar
I've had to do this 3 times in a row over 2 days, then another time removing the transmission. My trick was to use a 14mm (or was it 17mm) box end on the nut just above the starter, and use a ratchet with a loooooooong extension to get to the bolt head on the transmission side from underneath. Still a PITA, but it worked.
