Originally Posted by aaronced
i recently bought it,
unless the person you bought it from is a close friend or family member who you trust with upkeep of vehicles and or are known to be mechanically savvy. You should assume its just been sitting around un kept.
with the car running check for any signs cracked hoses.. specially the ones in the back.. Flush your rad. when re filling be sure to burp it to get the air out of the system.. did you hear any waterfall like sounds during acceleration?
oh OIL check for OIL! if you run the car a quart or more low you will start to overheat cause your essentially melting your engine! when you finished your 100 mile trip did you check your oil level?
