Easily comparable to the feel of the TEIN SS damper kit I tested, came with adjustable camber plate and it does get some big camber if you want it, rides really smooth with the dampers in the 1-8 stiffness range, and in the higher ranges makes the 3400lb supra feel like a feather, hardly any roll with the coilovers alone. I'll post some pictures up, I'm still trying to figure out how to get it lower without bottoming out on every small crack. I would recommend this for others looking for something a little cheaper then the TEIN SS series.
This is the only one I have before the coilover swap, its on eiback springs and struts in this picture, right after picking it up from the first owner.
