Crank, no spark
Reconditioned the injectors and now it runs , but only when I hard wire the starter. With the ignition on and running a wire from the starter and touching the battery, it starts and idles beautifully. A bit rough on acceleration, but I suspect the plugs or a faulty lead.
I bought another ignitor and coil and still no spark when cranking.
This is frustrating, as I've checked the voltages at the ECU for what feels like the tenth time. There is voltage at the coil when cranking.
The other problem I have is that the digital tacho isn't working either.
