Do check for boost leaks but code 51 and 52 are not stored in the ecu they are real time codes so the only way to check them is if the car is on and running... but your right he shouldn't check it while reviving it up. He needs to take a drive with the jumper out and if the check light comes on go check the code while car is still running at idle. Don't shut the car off or the code will clear
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
