power issue
ok i have fix the problem change the MAF back to the stock one and now the car runs great till i hit fuel cut. so now i have to get a regulator to build up the fuel to bout 58psi right? cause it still has the stock regulator which produces 38-40psi. once i hit fuel cut i have give it a min to build the fuel pressure back and then go again.
