It sounds fuel related, for sure. If good fuel pressure, than possibly injectors. There is a sock type filter either before the pump (pump external on the 83) or it's in the tank. You can check that. You could check/clean/replace the gas tank. Old car, who knows? Clogged fuel lines?
Good luck and ALWAYS check your vac lines and intake couplings
