Might have bad wheel bearings on one side (or both). This could cause the sensor to malfunction for the anti-lock. Also sounds like it could be the brake pad wear indicator telling you it's time to change the pads.
VT247
Originally Posted by rob87
So, I just had a new engine put in to my 87 manual turbo supra. The antilock light was never on before this engine swap. When I turn off the engine and start it back up the light doesn't come on but if I start driving, light will come on. I do hear every once in awhile a screeching sound coming from the driver side wheel and hitting the brakes doesn't change the sound. The screeching sound goes away if a turn the wheel a little to the left but the sounds comes right back when I straighten out the wheel. Not sure if that is related to my antilock light coming on.
