Thread: breaks went out
Old 09-02-2010, 07:19 AM   #1
Vacationtime247
Look for any leaks where the brake lines travel, if you see a leak, there's your problem. Probably time to bleed them also. Start at the passenger back, then driver back, passenger front, driver front. Unloosen the bleeder screw. To do a 1 man job at this use a broom or stick to depress the pedal and wedge between the seat. Tighten the screw. Release the pedal. Do this to each 2-3 times or until all the air is out. Make sure you have a full reservoir full of brake fluid before you start.
VT247
Originally Posted by jcastro View Post
i was heading to a stop sing and they just gave i quickly held the e break but then soon after they came back and i was going kinda fast but i have no idea what it was their back to normal now
