Just build an L shaped wall that the intake runs through (as shown in a number of threads on here) and you may call it done. If you want you may run a flexible dryer hose or some vinyl rain gutter from the foglight hole (yep, gotta lose the foglight) up to the opening to your boxed in area. The hose doesn't do anything if it's just run down behind the foglight.
