Old 09-13-2010, 10:21 PM   #2
Travis89Turbo
Travis89Turbo's Avatar
Fix your fuel leak before going any farther.. safety first. Pull the little wire from your starter and have someone turn the key and check for voltage. Again while wire is unhooked from starter. Don't pull the efi fuse or u will lose power to your ecu the main brain of the efi system and that's why its powered from the efi circuit. Check your connections on battery and make sure your ground is hooked to the block below intake manifold. Let us know
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
