Old 09-13-2010, 10:23 PM   #5
ochowdero
Originally Posted by Conga1991 View Post
What do you mean the efi fuse should do it?? explanation please?
your EFI fuse is for your injectors, a bad one basically tells your injectors to stop working and then in return your car is starving for gas. a good one just does what its spose to..
you have 2 fuse box, my EFI fuse is located under the hood on the drivers side, its a 15a and is labeled "EFI"
check the one under your hood, if not there, check the one in your car by the drivers kick panel
once you find it pull it out, if its good keep it, if not go get a new one..
then just turn your ignition to see if you get acouple clicks from the starter..nothing? then take a amp to see if your even getting power to it...
maybe you missed wires..
check the amp level any way, i think you should have 1.5? idk im not sure...
tell me if you get it working..
