Originally Posted by Conga1991
When I turn the key to turn it over theres one click noise coming from where the ecu is, which was kind of strange and I couldnt pin point where exactly where it was coming from.
Also the fuel is going cuz I hear a spray and I have a little fuel leak which Ill fix as well as a small coolant leak on my floor.
when i did the swap same clicking happened it was wierd.
A.starter was hooked up wrong
B.battery was dead (check that you have proper voltage.)
you need air fuel and spark.
your missing one...
