Old 09-14-2010, 05:12 AM   #13
916MKIIIx2
916MKIIIx2 is on a distinguished road
FYI, you pull the EFI fuse so your car wont be spitting fuel into the cylinders while doing voltage and amps checks on the starter, pulling the EFI fuse will in no way hinder you from making sure your "starter" is working, go to google and type in starter AMP test, and starter voltage test to see what you need to do. "I AM IN NO WAY SAYING THE EFI FUSE IS BAD" Just pull it before you do cranking tests.
916MKIIIx2 is offline   Reply With Quote
