Old 09-15-2010, 04:42 AM   #16
btwilson86
Super Moderator
btwilson86's Avatar
Which connection at the starter has no power, the little wire or the big one? If it's the big one, the only culprits can be a bad connection or bad wire. If it's the little one, the alarm is a possibility.
If the alarm is cutting out the starter, I believe you unlock the passenger door a couple of times with the key to disable it.
