http://www.supras.org.nz/techinfo/bhg.htm
See this link. All I did was a simple Google search to find this. Head gasket is the most common problem on the m series engine. You can send a sample of yoir oil to a company and they will tell u exactly what is in there. Very well could be antifreeze thining your oil causing low pressure. there is a block test you can do to tell u if you have a leaking head gasket. Is there any sign of oil in your antifreeze or any dissapearing coolant? How old is your oil?
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
