I unlocked and locked the passenger side and tried starting it and still nothing, but now the fuel leak is back so im gonna use some white plumber tape on the union. and im gonna replace the large wire from the battery to the starter hoping thats the problem.
So if the wires to the starter (large battery and small ecu plug) arent the problems, then the only thing causing the starter not to start is the ignition wiring?
