Old 09-16-2010, 06:00 AM   #24
ochowdero
Originally Posted by Conga1991 View Post
Thanks! I'll do that tomorrow and hopefully it will work, other then that I just got to fix the coolant leak and the fuel leak that I thought I fixed but didnt :/ so every time i try to turn it over it leaks a bit. but i pulled the efi fuse so it doesn flood the cylinders.
IIRC, the efi fuse keeps the ignition from firing...we had you pull it in the first place just to make sure your starter clicks(pulled it so when you turned the key fuel didnt flow into the cylinders)it didnt click meaning there was not enough power to run it..
plug your efi fuse back in after you test the battery and clean your cables..
other words itll never start
i believe the efi does that..either way plug it back in after you clean and test the battery
