Originally Posted by Travis89Turbo
It shouldn't do that...... so what I think is goin on is that washer that is on the starter caused the big or main cable to ground out on the starter its self. The 400mv u are getting is from a ground loop or otherwise known as ghost voltage so it has an open in the line. probably the fuse but possible ly the cable itself.
So I went to schucks to check if the starter is still good, its bad, didnt do anything. there was still enough plastic so the nut wouldnt touch the starter. So im buying a new one fom them for 70$, is that good for a brand new one? toyota parts store isnt open to call and get a quote.
