Thread: leaking engine
Old 09-20-2010, 03:38 AM   #19
If its starting a few inches BELOW the lower plenum the HG and Head/Timing plate packing are the likely problems. If it's starting at about the same level as the lower intake plenum the cam seal should be inspected and if it's getting on TOP of the lower intake plenum the valve cover seals are the most likely suspect.
