I did step on the clutch. Also what do you mean by grounded correctly?? the ground wire that goes all the way to the block and on the side of the bay then Yes. Also I replaced the positive battery cable not the negative.
For the ignition wiring, where do I start to check the continuity? the plug that goes into the starter?
