Do this. Using a volt meter check the voltage on the big wire at the starter using the block as a ground. That'll tell u if the battery is grounded properly. Then get back with us
Good voltage is 12.8... but the starter will activate between 11.8-14.4 volts
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
